Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Verifiy failed between adr.... in SRAM DE2-115 tPad Simple Socket Project
Hi There,
I try to build the SimpleSocketServer_rgmii_0 on my DE2-115 tPad.
I could generate the System in SopC and Quartus successfull but in Nios
I became this error message:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x014034E0: verified
Initializing CPU cache (if present)
OK
Downloading 01200000 ( 0%)
Downloading 01210000 (20%)
Downloading 01220000 (41%)
Downloading 01230000 (61%)
Downloading 01240000 (82%)
Downloaded 313KB in 5.3s (59.0KB/s)
Verifying 01200000 ( 0%)
Verify failed between address 0x1200000 and 0x120FFFF
Leaving target processor paused
In the System Lib Properties i set the Prog memory and the rest all of sram.
In SopC I use the SRAM-Controller from the University Program IP. I try also the IP from TERASIC --> TERASIC_SRAM, still with both version the same error.
I run also the Standalone Quartus Prog for program the sof file and then I leave the unlimited window open. I thing that are not the problem.
Please help me to find a solution
Thanks you
Antonio
in the attachment you find my SoPc System.
In NiosII I use the template simple_socket_server_rgmii_0
Grazie...
Had a similar problem with Terasic SRAM when it is connected to a NIOS II/f (NIOS II/e - no problem). This is because the II/f is much faster (can have transactions one after the other due to the pipeline that it has). I solved this by modifying the Terasic SRAM component in the SOPC system by adding having 2 read waitstates, 2 write waitstates, and 1 hold cycle and 1 setup cycle (this is probably an overkill, you could probably omit a few of the wait states or setup/hold cycles). Now it works without a problem with the II/f (NIOS CLK = 50 MHz). I recommend using the SDRAM for the NIOS, because it is faster and has more capacity than the Terasic SRAM. If you must use the SRAM, change the SOPC component as I indicated above.
