12603 Discussions
Warning: trying to use little-endian srec with big-endian hardware
Devi_Puthra
I am getting following error message when I am tryin to load elf file to the board in Max10 FPGA.
Using cable "T-Core [USB-1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
EricMunYew_C_Intel
Have you loaded your FPGA image? may I know which document you followed?
Devi_Puthra
Thanks for your reply. I resolved this issue, issue was basically related to clock
