12600 Discussions
What is DDR2 Clock Frequency Setting (Affect Niche Stack and VIC functionality)...?
Dear Friend's
I am using Altera ESDK-Cyclone-III board
My Application is to collect data from Synchronous port (1 Mbps) and forward it to Ethernet Port (TCP packets) & for testing i am using RS232 Port. but both ports and Vectored Interrupt Controller (VIC) won't work at time
1. Setting ddr2_bot clock from 165 to 150 mhz Results
1.1 Quartus: Critical Warning: Timing not met
1.2 Ping Stop Responding
1.3 VIC receive all the interrupt
2. Setting ddr2_bot clock from 150 to 125 mhz Results
2.1. Quartus: Critical warning removed: Timing not met
2.2. Ping Stop Responding
2.3. VIC Collect all the Interrupt
3. Setting ddr2_bot clock back to 165 mh Results
3.1 Quartus: Critical Warning: Timing not met
3.2 Ping Responding
3.3 VIC not able to receive all the interrupt
3.4 after interrupt activity ping also stop responding
Kaushal
Attached is my SOPC File for Reference....
