12603 Discussions
When i use eclips on Quartus Prime21.1 LE, When oparation File→New
Hiro505
If you have any time please tell me how to use it.
When i use eclips on Quartus Prime21.1 LE, When oparation File→New,
There aren't "Nion Ⅱ Application and BSP Template” and so on.
Why?
What kind of operation does it need?
If you have any ideas, please tell me.
Thank you for reading.
EBERLAZARE_I_Intel
Have you installed below?:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
After a fresh install of Quartus lite 22.1 in Windows 10 and do the installation above, I can see the same output as the "Good" you shared, when opening the eclipse.exe at "intelFPGA_lite\22.1std\nios2eds\bin\eclipse.exe".
Hiro505
Thank you for your imformation.
But i already done it before.
EBERLAZARE_I_Intel
Any update from your side?
EBERLAZARE_I_Intel
Please check my previous responds.
EBERLAZARE_I_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer/mark as solution or rate 4/5 survey.
Hiro505
sorry to responce  late.
I couldn't have been fix it.
I already done it.
But I'll retry it.
