12471 Discussions
Where are hwlibs for Cyclone V SoC HPS EMAC?
corestar
I need to write a driver for the HPS EMAC. The rev 18.0 hwlibs do not seem to have any functions to control the EMAC.
I'm used to Xilinx Zynq which has a large API of functions in the BSP to do things such as XEmacPs_CfgInitialize to initialize and EMAC, XEmacPs_SetMacAddress, and XEmacPs_SetHandler to set interrupt handlers etc. Is there nothing similar in Altera????
Abe
Valued Contributor II
The HWLIBS for Cyclone V SoC are present only in the Standard Version of Quartus Prime and EDS only. The Pro version will support only Cyclone 10, Arria 10 and Stratix10 SoCs.
corestar
@Abe​ , I'm using the Quartus Standard since Pro does not support Cyclone V at all. But there don't appear to be any hwlibs for the EMAC.
corestar
To be more specific, I've attached a screenshot the HWLIBS docs. A large number of functions for things such as the UART, I2C etc, but nothing for the EMAC.
Abe
Looks like only the Register space for the EMAC is defined in the HWLIBs. I do not see any API documentation. You can find this information under Address Space -> Component: EMAC Module - ALT_EMAC.
Intel (Altera) does mention the following:
WARNING: The C register and register group struct declarations are provided for convenience and illustrative purposes. They should, however, be used with caution as the C language standard provides no guarantees about the alignment or atomicity of device memory accesses. The recommended practice for writing hardware drivers is to use the SoCAL access macros and alt_read_word() and alt_write_word() functions.
Looks like we have to write our own drivers for the EMAC using the register space provided and the alt_write_word() and alt_read_word() functions.
If you look into the following location you will find the emac header file:
/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av/socal
