12599 Discussions
Where can i get "advanced_boot_copier.c " file?
Hi all,
Where can i get "advanced_boot_copier.c "?
In an458 document of niosII_docs_8_0, it guides:
"The source code for the default boot copier is included with the Nios II
embedded design suite (EDS) in the <Nios II EDS install path>/
components/altera_nios2/boot_loader_sources directory, or in the
Nios II literature page ( www.altera.com/literature/lit-nio2.jsp) with this
document."
But i did not see the source code such "andvanced_boot_copier.c" and "advanced_boot_copier.h "
(an458.pdf document is about NIOS boot methods)
Thanks for your helps in advance!
Konpaba
Here you go:
http://www.altera.com/literature/an/an458_design_example_files.zip
You have to go to the bottom of the page and expand the "SOPC Builder System Development" section.
Jake
--- Quote Start ---
Here you go:
Jake
--- Quote End ---
Thanks your very quick, useful reply so much!
Thanks you guys, get the example finally almost ten years later. I think if the links of example put in front of an458.pdf will easier for the readers.
