12603 Discussions
Where specify the path for #include files in NIOS II Eclipse
I'm new in NIOS development tools and apologize in advance for probably silly question.
So, the question is: How to take into account the .h files that are referenced (by #include statements) in the source code. I suppose that there are 2 options:
  • Add these files in the application directory tree (right-clicking on the project I didn't find respective option)
  • Add the path to these .h files somewhere in the project option (where exactly ? because exploring project options I didn't find an option for specifying path for .h files)
Here, for example, the snapshot from a simple project, taken from the book "embedded sopc design with nios ii processor and verilog examples"
The compilation errors are related to unrecognized types alt_u8, alt_u32, that are declared here:
c:\altera\15.1\ip\altera\nios2_ip\altera_nios2\hal\inc\alt_types.h
Thanks in advance.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13314&stc=1
Finally I've found the location where the path to .h file must be specified.
Here it is: project-->settings-->c/c++ general-->paths and symbols-->includes tab
Here I've added the location (button Add...) to .h files: c:\altera\15.1\nios2eds\components\altera_nios2\hal\inc
After compilation this path appeared in the project "Includes" folder.
Nevertheless the compilation failed: an error is found in the source file alt_main.c (please see the screenshot below).
Any ideas ?
https://www.alteraforum.com/forum/attachment.php?attachmentid=13316
Resolved,
One needs to add the main application source file (where the function main is located) in elaboration process.
Referring to the screenshot below, one should right-click on the source file and click on "add to nios ii build"
After this the application is built without errors.
https://www.alteraforum.com/forum/attachment.php?attachmentid=13317
Here is build result without errors (with added source file to build process) - .elf file is generated.
https://www.alteraforum.com/forum/attachment.php?attachmentid=13318
Try main application source file (where the function main is located) in elaboration process.
