12600 Discussions
Whether do the adress&data shared lead to the ucLinux downloaded error?
Hi,everyone. the ucliux was downloaded error with the project of the StratixIV not being changed.So I thought whether do the adress&data of the flash and ssram shared lead to the ucLinux downloaded error or not?
Thanks!
Is it all ok with timing analysis?
Thank you for your reply!
Yes, the compilation of the Quartus is OK!
Kind Regards
I got it by changing the address which must be correspondence with the address of the ssram in the Qsys is in the "link address offset for booting" of nios2 uclinux menuconfig!
