12600 Discussions
Who have the code of Scatter-Gather DMA?
I meet a lot of problems of Scatter-Gather DMA,i do not have the example of Scatter-Gather DMA.it is very hard to make it.some one who have the code of Scatter-Gather DMA please upload it.
thanks in advance
Here you go: http://www.altera.com/support/examples/nios2/exm-scatter-gather-dma.html
There will be a new "Modular SGDMA" that will be posted up on the Nios II design examples page shortly. It doesn't use descriptor fetching and as a result is much easier to use in my opinion. If you want to take a look at it send me a message with your email address and I'll forward it to you. This is the Modular SGDMA feature list that isn't present in the SGDMA today:
  • Up to 4GB transfer lengths
  • ST-->MM early termination (packet length limiting)
  • Interrupts per descriptor
  • MM-->ST error signal
  • Burst boundary re-alignment
  • Park mode built into the descriptor (makes frame buffering easy)
  • Descriptor sequence numbering (tag the descriptors then readback from the SGDMA to find out which descriptor the read and write masters are working on)
  • Descriptor programmable burst
  • Descriptor stride (address increment for fixed/interleaved data)
  • Data widths up to 1024 bits
  • Independent reads and writes (i.e. descriptors are dual buffered so the write master does not block the read master from starting up again)
  • Burst lengths up to 1024 beats
  • User selectable data/descriptor FIFO depths
-JCJB
thank you for your suggestion,but i want to learn the descriptor to control the SGDMA,so i wish you give me an example of the SGDAM.
my mailbox address is:
li_polaris_1988@yahoo.cn
thank you very much
this link is not available. please re-update link.
It was moved to the alterawiki. If you search for "modular SGDMA" on the wiki it should bring you to the correct page.
Thank you so much.
