mSGDMA Prefetcher parameters for TSE Sending:
-Data Path: 512
-Descriptor: 256
-Maximum transfer: 2KB
-Transfer type: Aligned
-Burst enabled
-Burst count: 128
-Force burst aligned enable
-Packet support enabled
-Error enabled: 1
-Enable prefetching module
mSGDMA Prefetcher Software algorithm:
Reset:
set ALT_MSGDMA_PREFETCHER_CTRL_RESET_SET_MASK;
while ALT_MSGDMA_PREFETCHER_CTRL_RESET_GET;
set ALTERA_MSGDMA_CSR_RESET_MASK;
while ALTERA_MSGDMA_CSR_RESET_STATE_MASK;
Init descriptor:
next_descriptor-control: reset ALT_MSGDMA_PREFETCHER_DESCRIPTOR_CTRL_OWN_BY_HW_CLR_MASK;
descriptor-read_address: set addres;
descriptor-write_address: set 0;
descriptor-transfer_length: set lenght;
descriptor-next_desc_ptr: set next_descriptor;
descriptor-control: set ALT_MSGDMA_PREFETCHER_DESCRIPTOR_CTRL_OWN_BY_HW_SET_MASK, ALTERA_MSGDMA_DESCRIPTOR_CONTROL_GENERATE_SOP_MASK, ALTERA_MSGDMA_DESCRIPTOR_CONTROL_GENERATE_EOP_MASK, ALTERA_MSGDMA_DESCRIPTOR_CONTROL_GO_MASK;
mSGDMA Start:
while ALT_MSGDMA_PREFETCHER_CTRL_RUN_GET;
set ALTERA_MSGDMA_CSR_STOP_DESCRIPTORS_MASK;
load descriptor IOWR_ALT_MSGDMA_PREFETCHER_NEXT_DESCRIPTOR_PTR_LOW;
IOWR_ALT_MSGDMA_PREFETCHER_NEXT_DESCRIPTOR_PTR_HIGH: set 0;
set ALTERA_MSGDMA_CSR_STOP_ON_ERROR_MASK;
reset ALTERA_MSGDMA_CSR_STOP_DESCRIPTORS_MASK;
set ALT_MSGDMA_PREFETCHER_CTRL_RUN_SET_MASK;
