Dear all,
I have do experiment on the Cyclone V SOC. [Helio evaluation board] And I put one nios/e and onchip-ram into the FPGA fabric. Currently, I could read/write the data in/out from Onchip RAM. Now, I am measuring the time duration for my source code. I discover that each instruction runs slowly. Below is my simple source code. I don't understand that the one line[*pdata = i++;] I comment , it needs to take 1us. It should not be correct performance. Or should I choose the better version of Nios II ? Anyone could suggest or hint me why and what to do? Attached file is my zip file of QSYS. # include <stdio.h># include "system.h"# include "altera_avalon_pio_regs.h" unsigned int LED_TOGGLE = 0; unsigned char *pData = ONCHIP_MEMORY2_1_BASE; int main() { int i = 0; printf("Hello from Nios II!\n"); while(1) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,LED_TOGGLE); LED_TOGGLE = ~LED_TOGGLE; //*pdata = i++; } return 0; }Link Copied
Use NIOS /f and compile without debug information and with optimizations
How are you measuring the time?
Hi, I use scope[logic analysis] and connect the LED output.
And comment / dis-comment the line of [write data]. check time difference between comment and dis-comment.- Mark as New
What is your clock speed ?
I presume much faster than 1MHz.- Mark as New
According to my QSYS,
All components[including NiosII] are connected to clk and it is default for 50Mhz.- Mark as New
Ok, good. Another thing to try is to instrument Nios with SignalTap and see what instructions it executes in that slow line of code. See the following document, page 17: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an446.pdf- Mark as New
Count the instructions in the loop:
1) Read of LED_TOGGLE for the io_write 2) Write of LED_TOGGLE to the hardware 3) Read of LED_TOGGLE for the invert 4) the invert inself 5) Write back of LED_TOGGLE 6) Unconditional branch IIRC a nios/e takes 5 clocks per instruction - so that is at least 30 clocks. The constant LED_PIO_DATA_BASE might also be created each loop iteration. Add in any extra clocks for the avalon write caused by your slave itself. Make LED_TOGGLE a local variable (so it can be assigned to a register). Compile with -O2 so that the compiler moves some calculations outside the loop. That should get you to a three instruction loop.- Mark as New
Thanks for all suggestion.
Because my Quartus II/NiosEDS is web edition, some option does not appear like optimization and version of Nios. I select subscription edition of Quartus, choose Nios/F and select opt to O2 or O3. It seems to get better performance. Thanks a lot for everyone.- Mark as New
actually, i am still wondering what do toy mean by slowly..
Topic Options
