HI,
I had created a custom component using qsys and using avalon MM interface. The base address was assigned as 0x5050. I'm using the command below for write and read operations. IOWR_32DIRECT(CUSTOM_COMPONENT_0_BASE, 0,4); INFO = IORD_32DIRECT(CUSTOM_COMPONENT_0_BASE, 0) It seems to me the write API was not functioning as the INFO is showing 1 instead 4. I'm currently using Quartus13. Is anyone know the reason/clues why the data is not being written correctly? Thanks HYLink Copied
This link might be helpful. It points to a previous discussion.
