Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Writing to UART
Simple code, trying to write to UART from terminal and light an LED if character "A" is detected. What am i doing wrong? here is the code. The manual of UART is here under \devices: http://www-ug.eecg.toronto.edu/msl/nios.html
# include <stdio.h># define RS232_UART_DATA ((volatile int*) 0x10001010)# define RS232_UART_CONTROL ((volatile int*) (0x10001010+4))
volatile int*LED =(int*)0x10000010;
int main()
unsigned char *pinput;
while(*pinput){
//strings in C are zero terminated
//if room in output buffer
if((*RS232_UART_DATA)&0xffff0000 )
//then read the next character
*(pinput)= *RS232_UART_DATA;
if (pinput =='A'){
*(LED)=1; }
Check your compiler warnings. 'pinput' is an uninitialized pointer variable and it's entirely possible it is pointing at garbage memory containing a zero when your program starts.
do confirm if the value that pinput is holding when any car detected.
