Background:
I am working with the Atlas/DE0-Nano-SoC Cyclone V board, and I have Yocto (krogoth branch) building fine with the linux-altera kernel (4.6 from krogoth branch, patched with PREEMPT RT) and Linaro gcc (5.3 from master branch), using the default device tree (socfpga_cyclonev_de0_sockit - actually, it builds and installs about 5 of them, and I have to rename this one on the SD card to socfpga.dtb). Problem: Now I want to work with the FPGA, and I'm starting out by pushing some I/O out through the FPGA fabric to the GPIO pins. I have the devicetree source generated from Quartus and sopc2dts. I was rather surprised that none of the Altera/Rocketboards or Yocto documentation seems cover integrating a custom device tree with the Yocto build, but I have scoured the web looking for information, and have come up short on finding an actual solution. Things I've done/tried: - adding to the kernel recipe to copy the .dts into the kernel source - change KERNEL_DEVICETREE to match: --- the base filename of the .dts (socfpga_cyclone5_mydevtree) --- the full filename of the .dts (socfpga_cyclone5_mydevtree.dts) --- the full filename of the desired .dtb (socfpga_cyclone5_mydevtree.dtb) --- the full path and filename of the .dts (/path/to/socfpga_cyclone5_mydevtree.dts) - similarly change KERNEL_DEVICETREE_cyclone5 - change both KERNEL_DEVICETREE and KERNEL_DEVICETREE_cyclone5 to matching or different versions of the above - editing the Makefile in ${TMPDIR}/work-shared/cyclone5/kernel-source/arch/arm/boot/dts to include a target for my desired .dtb - many other things that seemed to make sense at the time... I can actually get the device tree blob built (but it requires running bitbake twice and changing KERNEL_DEVICETREE and/or KERNEL_DEVICETREE_cyclone5 between runs - I'd like to fix that). Then bitbake errors out building the SD card image because somehow it's still trying to include 5+ versions of the .dtb, even though I have overwritten the variable it's supposed to be looking at for that list (KERNEL_DEVICETREE). Any help would be greatly appreciated! Thanks,Link Copied
