Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
12484 Discussions
YoctoPlugin SoCKit Altera Cyclone 5
Hello everyone. I have an issue when I try to build image via bitbake command of Yocto Project.
I did follow this guide of Altera http://download.altera.com/akdlm/software/soceds/cb/embedded_linux_getting_started_guide.pdf
The error come when I use this command to build image bitbake virtual/kernel virtual/bootloader altera-image
I'm using Ubuntu 16.04 LTS. I searched in the Internet and some people say that error because the version of my Ubuntu distribution I'm using. I'm so confuse now. Please help me. Thanks
OEROOT=/home/hohaidang/yocto
# ## Shell environment set up for builds.# ##
You can now run 'bitbake <target>'
Common targets are:
bitbake virtual/bootloader
bitbake altera-gsrd-image
bitbake altera-image
hohaidang@hohaidang-PC:~/yocto/build$ bitbake virtual/kernel virtual/bootloader altera-imagePseudo is not present but is required, building this first before the main build
WARNING: Host distribution "Ubuntu 16.04.1 LTS" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |#######################################################| ETA: 00:00:00
Loaded 1174 entries from dependency cache.
Parsing recipes: 100% |#####################################################| Time: 00:00:01
Parsing of 878 .bb files complete (857 cached, 21 parsed). 1202 targets, 111 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION = "1.16.0"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "socfpga_cyclone5"
DISTRO = "poky"
DISTRO_VERSION = "1.3"
TUNE_FEATURES = "armv7a vfp neon callconvention-hard cortexa9"
TARGET_FPU = "vfp-neon"
meta
meta-yocto
meta-yocto-bsp
meta-yocto-bsp
meta-altera
meta-linaro = "<unknown>:<unknown>"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: sysroot_stage_all (see /home/hohaidang/yocto/build/tmp/work/x86_64-linux/quilt-native-0.60-r0/temp/log.do_populate_sysroot.7796 for further information)
ERROR: Logfile of failure stored in: /home/hohaidang/yocto/build/tmp/work/x86_64-linux/quilt-native-0.60-r0/temp/log.do_populate_sysroot.7796
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing python function do_populate_sysroot
| DEBUG: Executing shell function sysroot_stage_all
| tar: '--same-order' cannot be used with '-c'
| Try 'tar --help' or 'tar --usage' for more information.
| tar: This does not look like a tar archive
| tar: Exiting with failure status due to previous errors
| DEBUG: Python function do_populate_sysroot finished
ERROR: Task 10 (/home/hohaidang/yocto/meta/recipes-devtools/quilt/quilt-native_0.60.bb, do_populate_sysroot) failed with exit code '1'
NOTE: Tasks Summary: Attempted 23 tasks of which 22 didn't need to be rerun and 1 failed.
No currently running tasks (7 of 63)
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
I found out by finding a post that Ubuntu 14.04 and above are only supported by Yocto 1.6 and above:
https://www.mail-archive.com/yocto@yoctoproject.org/msg18678.html
Here you can get a newer version and be successful https://www.yoctoproject.org/downloads
