I am working on altera De2-70 board, using altera monitor program. i am continuously getting errors for syntax in c on altera monitor program. does it use different syntax or just same as c programming?
/* //the worked simple blink code # define switches (volatile char *) 0x0002000 # define leds (char *) 0x0002010 void main(){ while (1) *leds = *switches; }*/Link Copied
"00111000" is a octal number
"111000" would be decimal "0b00111000" would be binary To get "A" use: A = (*switches>>0) & 0x07; B= (*switches>> 3) & 0x7; op = (*switches >> 6) & 0x3;
Topic Options
