hi iam new i nios 2, i just want to know how to get the delaycount in the program of the delay below:
delay : movi r5, delaycount loop : subi r5 , r5 ,1 bne r5 , r6, loop ret need the answer as quick as possible and thanx in advance.Link Copied
Have you tried find/grep for the delaycount value? You probably could see it from the eclipse-nios2 GUI.
--- Quote Start --- Have you tried find/grep for the delaycount value? You probably could see it from the eclipse-nios2 GUI. --- Quote End --- ok thnx i will try it.
