Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
a problem about interrupt
hello ,i met a problem about interrupt,i define a led to test the initerrupt(when generate a interrupt the led is off) ,and a inputport (only 1BIT). The rising edge generate the interrupt.
the following is my code # include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"
static void handle_PIO_1_interrupts(void* context, alt_u32 id)
{volatile int* nihao=(volatile int*)context;
*nihao=IORD_ALTERA_AVALON_PIO_EDGE_CAP(PIO_1_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(PIO_1_BASE,0);
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(PIO_1_BASE,0Xf);
IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, 0);}
volatile int edge;
int main()
alt_irq_register(PIO_1_IRQ,(void*) &edge, handle_PIO_1_interrupts);
IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, 1);
while (1)
return 0;
can anybody help me,or give me an example about interrupt(except count_binary.c) thanks
