Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
about .rbf option
In the device option I select the .rbf option to generate a raw binary file,but after compile that, the .sof can't be download into the FPGA. the error info:
Error: CONF_DONE pin failed to go high in device 1
Error: Operation failed
my software version is : QII4.0+sp1. my board is 1s10 from altera.
who konws the reson?
BTW: the .rbf is equivalent to .bin?
thank u!
Highlighted
Re: about .rbf option
I have such trouble when in Quartus in Select Device options wath selected incorrect device. Check your kit - some of them are with ES devices. 1s10ES for example. If you try to programm it with file generated for 1S10 device you got error.
Check the options.
Highlighted
Hi, tahnk u your reply.
if I program the .rbf into the Flash in 0x600000(user section), can the EPM drag the user image to FPGA correctly when Powe on?
Highlighted
Yes,I only want to confirm it.
