about reset vector address
hi everybody
I want to know If I debug use the JTAG , does the reset vector address have any influence ? I set the reset vector address on ext flash.
where do the code start to run ?
Which external flash are you using?
--- Quote Start ---
--- Quote End ---
nor flash.where do the code run from when debug using the jtag?
Are you referring to debug code?
--- Quote Start ---
--- Quote End ---
yes ,when debug code
The CPU starts from your reset vector address. Debug does not affect your application code.
