hello all:
i want to build a 32 bits nios2 system with two sram(IS61LV256) and one flash (am29lv160) . Can anybody tell me how to link them with address. thank youLink Copied
It's dynamic alignement, if I understand you right. And in this case SRAM and FLASH connect to A[0].
If the SRAM is 32bit in your case, in my opinion, the A0 of SRAM should be connected to A2 of the Nios;
while, if your Flash is 8bit wide, then connect A0 to A0 will be OK. At least, the "avalon bus specification" says this.- Mark as New
thank you .
if my Flash is 16bit wide, the A0 of the flash should connect to" A0 OR A1" of the nios?- Mark as New
Table 15 Page 100 of Avalon Bus Specification:
in case of NIOSII: Master Width is always 32 native Alignement = Avalon Register Slave dynamic Alignement = Avalon Memory Slave Alignment | Master Width | Slave Width | A[0] of Slave is connected to Byte Address Bit Number native | 32 | 32 | A2 native | 32 | 16 | A2 native | 32 | 8 | A2 dynamic | 32 | 32 | A2 dynamic | 32 | 16 | A1 dynamic | 32 | 8 | A0 so you have to connect A0 of your flash to A1 of nios address bus.
