hi
i build nios system with timer and set the bsp (timestamp,timer) compile is ok but when i run the alt_timestamp_start() get -1 and alt_timestamp() also return -1 !! the nticks() work good i read post from 2005 ""I can't see it clearly, but I think you set both your sys_clk_timer and timestamp_timer to be timer0? Can you disable the sys_clk_timer instead? Also remember to press the generate button."" i was do this mistake too should i fix this ?? i fix that ""sys_clk_timer and timestamp_timer can not be timer0?"" i disable the sys_clk_timer on the bsp editor tzahiLink Copied
Check out this theme, looks like the same
https://forums.intel.com/s/question/0D50P00004AzEOPSA3/niosll-interval-timer-is-not-enabled
Topic Options
