12604 Discussions
altera_avalon_tse.h and _TIMEOUT_THRESHOLD #defines
We are using NIOS2 with uCOS2 and the NicheStack and need to be able to
run our embedded app even if we don't have a network connection.
We noticed with the below default altera_avalon_tse.h settings,
the processor hangs up and seems to hold interrupts causing the app
to have issues loading.
# define ALTERA_AUTONEG_TIMEOUT_THRESHOLD 250000# define ALTERA_CHECKLINK_TIMEOUT_THRESHOLD 1000000# define ALTERA_NOMDIO_TIMEOUT_THRESHOLD 1000000# define ALTERA_DISGIGA_TIMEOUT_THRESHOLD 5000000
I tried these settings and it allowed to progress without a network connection fine,
but this seems like overkill.
Is there another Altera# define or code block that would allow obtaining the IP in
a lower priority task/thread ?
# define ALTERA_AUTONEG_TIMEOUT_THRESHOLD 2500# define ALTERA_CHECKLINK_TIMEOUT_THRESHOLD 1000# define ALTERA_NOMDIO_TIMEOUT_THRESHOLD 10000# define ALTERA_DISGIGA_TIMEOUT_THRESHOLD 50000
Is the below change an appropriate fix ?
I found that I needed to change the below code in
BSP\drivers\src\altera_avalon_tse.c
in the alt_tse_phy_restart_an() function.
Adding a 1 second sleep in this while loop allows background tasks (we use uCOS2) to have some cpu cycles. A timeout of 10 seconds would be sufficient.
The iNiche network initialization (again initialization only) is also on a task as well.
while(alt_tse_phy_rd_mdio_reg(pphy, TSE_PHY_MDIO_STATUS, TSE_PHY_MDIO_STATUS_AN_COMPLETE, 1) == 0 )
usleep(1000000); /* sleep for 1 second */
/* change to time out after 10 seconds */
if(timeout++ > 10 /*timeout_threshold*/) {
tse_dprintf(4, "WARNING : PHY[%d.%d] - Auto-Negotiation FAILED\n", mac_group_index, mac_info_index);
/* Restore previous MDIO address */
alt_tse_phy_wr_mdio_addr(pphy, mdioadd_prev);
return TSE_PHY_AN_NOT_COMPLETE;
