Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
12455 Discussions
altera simple socket server troubles
I need to provide TCP/IP connection with speed ~10 Mbit/s
with Cyclone IV Development board.
It provides 10/100/1000 BASE-T Ethernet connection via a Marvell
88E1111 PHY and the FPGA-based Altera Triple Speed Ethernet
MegaCore function in RGMII mode.
I use altera simple socket server example to transmit 1500 bytes payloads.
It tranfer several packets and stop whithout any activity.
Server code:
# include <stdio.h># include <errno.h> # include <alt_iniche_dev.h># include "ipport.h"# include "libport.h"# include "osport.h"# include "tcpport.h" # define IP4_ADDR(ipaddr, a,b,c,d) ipaddr = htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) | ((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff))) # define IPADDR0 192# define IPADDR1 168# define IPADDR2 0# define IPADDR3 200 # define GWADDR0 0# define GWADDR1 0# define GWADDR2 0# define GWADDR3 0 # define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0 # include "global.h" int get_mac_addr(NET net, unsigned char mac_addr) { // This is the Altera Vendor ID mac_addr = 0x0; mac_addr = 0x7; mac_addr = 0xed; // Reserverd Board identifier mac_addr = 0xFF; mac_addr = 0x00; mac_addr = 0x02; printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n", mac_addr, mac_addr, mac_addr, mac_addr, mac_addr, mac_addr); return 0; } int get_ip_addr(alt_iniche_dev *p_dev, ip_addr* ipaddr, ip_addr* netmask, ip_addr* gw, int* use_dhcp) { IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3); IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3); IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3); *use_dhcp = 0; printf("Static IP Address is %d.%d.%d.%d\n", ip4_addr1(*ipaddr), ip4_addr2(*ipaddr), ip4_addr3(*ipaddr), ip4_addr4(*ipaddr)); /* Non-standard API: return 1 for success */ return 1; } # define BUF_SIZE 1500 //1500 # define TASK_STACKSIZE 2048 OS_STK InitialTaskStk;# define INITIAL_TASK_PRIORITY 5 void work_server() { char buff; int socket, len; struct sockaddr_in incoming_addr; //server_socket int fd_listen, max_socket; struct sockaddr_in addr; fd_set readfds; if ((fd_listen = socket(AF_INET, SOCK_STREAM, 0)) < 0) { printf(" Socket creation failed\n"); while(1); } addr.sin_family = AF_INET; addr.sin_port = htons(9000); addr.sin_addr.s_addr = INADDR_ANY; if ((bind(fd_listen,(struct sockaddr *)&addr, sizeof(addr))) < 0) { printf("Bind failed \n"); while(1); } if ((listen(fd_listen, 1)) < 0) { printf("Listen failed\n"); while(1); } len = sizeof(incoming_addr); FD_ZERO(&readfds); FD_SET(fd_listen, &readfds); max_socket = fd_listen+1; while(1) { printf("wait accept client\n"); select(max_socket, &readfds, NULL, NULL, NULL); if (FD_ISSET(fd_listen, &readfds)) { if((socket = accept(fd_listen, (struct sockaddr*)&incoming_addr, &len)) < 0) { printf("accept failed\n"); continue; } else { printf("accept OK\n"); int bytes_recv, nsize = 0; while((bytes_recv = recv(socket, buff, BUF_SIZE, 0)) != SOCKET_ERROR) { //printf("\n\nbytes_recv = %d\n", bytes_recv); bytes_recv = send(socket, buff, bytes_recv, 0); nsize++; printf("nsize = %d\n", nsize); } printf("\n\n\nSOCKET_ERROR\n\n\n"); } } } } TK_OBJECT(to_task); TK_ENTRY(work_server); struct inet_taskinfo server_task = { &to_task, "server", work_server, 6, APP_STACK_SIZE, }; void InitialTask(void *task_data) { alt_iniche_init(); netmain(); printf("wait inich\n"); while (!iniche_net_ready) TK_SLEEP(1); TK_NEWTASK(&server_task); OSTaskDel(OS_PRIO_SELF);// del self task while (1); } int main (int argc, char* argv, char* envp) { /* Clear the RTOS timer */ OSTimeSet(0); /* SSSInitialTask will initialize the NicheStack * TCP/IP Stack and then initialize the rest of the Simple Socket Server example * RTOS structures and tasks. */ OSTaskCreateExt(InitialTask, NULL, (void *)&InitialTaskStk, INITIAL_TASK_PRIORITY, INITIAL_TASK_PRIORITY, InitialTaskStk, TASK_STACKSIZE, NULL, 0); /* * As with all MicroC/OS-II designs, once the initial thread(s) and * associated RTOS resources are declared, we start the RTOS. That's it! */ OSStart(); while(1); /* Correct Program Flow never gets here. */ return -1; } Client code:
# include <stdio.h># include <string.h># include <winsock2.h># include <windows.h> # pragma comment(lib, "ws2_32.lib") # define PORT 9000# define SERVERADDR "192.168.0.200" //#define SERVERADDR "127.0.0.1" DWORD WINAPI RecvMess(LPVOID pmy_sock); # define COUNT_DATA 256 // 10240 &#1087;&#1086; 1024 = 10 Mb# define NN 1024 // size buffer int ready = 1; int main(int argc, char* argv) { DWORD thID; char buff; printf("TCP DEMO CLIENT\n"); if (WSAStartup(0x202,(WSADATA *)&buff)) { printf("WSAStart error %d\n", WSAGetLastError()); return -1; } SOCKET my_sock; my_sock = socket(AF_INET,SOCK_STREAM,0); if (my_sock < 0) { printf("Socket() error %d\n",WSAGetLastError()); return -1; } sockaddr_in dest_addr; dest_addr.sin_family=AF_INET; dest_addr.sin_port=htons(PORT); if (inet_addr(SERVERADDR) != INADDR_NONE) dest_addr.sin_addr.s_addr=inet_addr(SERVERADDR); // &#1089;&#1086;&#1077;&#1076;&#1080;&#1085;&#1077;&#1085;&#1080;&#1077; if (connect(my_sock,(sockaddr *)&dest_addr, sizeof(dest_addr))) { printf("Connect error %d\n",WSAGetLastError()); WSACleanup(); fgets(buff, sizeof(buff)-1, stdin); return -1; } printf("Connect with %s successfully\n\n", SERVERADDR); CreateThread(NULL, NULL, RecvMess, &my_sock, NULL, &thID); int nsize = 0; for(int i = 0; i < NN; i++) buff = (char)(i&0xFF); DWORD time = GetTickCount(); while(nsize < COUNT_DATA) { nsize++; send(my_sock, buff, NN,0); Sleep(1); } printf("Wait recv full\n"); while(ready) Sleep(1); time = GetTickCount() - time; printf("time = %ld\n", time); fgets(buff, sizeof(buff)-1, stdin); closesocket(my_sock); WSACleanup(); return 0; } DWORD WINAPI RecvMess(LPVOID pmy_sock) { //FILE *fd; char buff; int bytes_recv; SOCKET my_sock; my_sock = *((SOCKET*) pmy_sock); /*fd = fopen("recv_file.txt", "wb"); if(fd == NULL) { printf("error fopen\n"); return 1; }*/ int nsize = 0; while(nsize < COUNT_DATA) { bytes_recv = recv(my_sock, buff, NN, 0); if (bytes_recv == SOCKET_ERROR) { printf("error recv\n"); break; } /*if(bytes_recv != fwrite(buff, sizeof(char), bytes_recv, fd)) { printf("error fwrite\n"); break; }*/ nsize++; } //fclose(fd); ready = 0; return 0; }
There is a number of reasons which can cause your application to stop.
First of all you must know if the whole application crashes or it's a matter of a single task;
use a separate tasks to toggle a signal or blink a LED in order to understand this.
Also try to keep the send queue limited. I mean, before sending more data, wait until you received a certain amount. For example, if you were transmitting 1,2,3, etc. , don't send N until you have received N - K, where K is the queue limit you choose.
If this way the system works, then you have a problem with your task stack size or with memory available for managing network packets.
I met the same problem....my program is nearly the same as you posted above.
I use DM9000A/Nichestack now,and it stop receiving packets after calling send function several times.it blocks in select function,and can't return.
can you tell me how to solve this problem?
