12603 Discussions
altera simple socket server troubles
I need to provide TCP/IP connection with speed ~10 Mbit/s
with Cyclone IV Development board.
It provides 10/100/1000 BASE-T Ethernet connection via a Marvell
88E1111 PHY and the FPGA-based Altera Triple Speed Ethernet
MegaCore function in RGMII mode.
I use altera simple socket server example to transmit 1500 bytes payloads.
It tranfer several packets and stop whithout any activity.
Server code:
# include <stdio.h># include <errno.h> # include <alt_iniche_dev.h># include "ipport.h"# include "libport.h"# include "osport.h"# include "tcpport.h" # define IP4_ADDR(ipaddr, a,b,c,d) ipaddr = htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) | ((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff))) # define IPADDR0 192# define IPADDR1 168# define IPADDR2 0# define IPADDR3 200 # define GWADDR0 0# define GWADDR1 0# define GWADDR2 0# define GWADDR3 0 # define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0 # include "global.h" int get_mac_addr(NET net, unsigned char mac_addr) { // This is the Altera Vendor ID mac_addr = 0x0; mac_addr = 0x7; mac_addr = 0xed; // Reserverd Board identifier mac_addr = 0xFF; mac_addr = 0x00; mac_addr = 0x02; printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n", mac_addr, mac_addr, mac_addr, mac_addr, mac_addr, mac_addr); return 0; } int get_ip_addr(alt_iniche_dev *p_dev, ip_addr* ipaddr, ip_addr* netmask, ip_addr* gw, int* use_dhcp) { IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3); IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3); IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3); *use_dhcp = 0; printf("Static IP Address is %d.%d.%d.%d\n", ip4_addr1(*ipaddr), ip4_addr2(*ipaddr), ip4_addr3(*ipaddr), ip4_addr4(*ipaddr)); /* Non-standard API: return 1 for success */ return 1; } # define BUF_SIZE 1500 //1500 # define TASK_STACKSIZE 2048 OS_STK InitialTaskStk;# define INITIAL_TASK_PRIORITY 5 void work_server() { char buff; int socket, len; struct sockaddr_in incoming_addr; //server_socket int fd_listen, max_socket; struct sockaddr_in addr; fd_set readfds; if ((fd_listen = socket(AF_INET, SOCK_STREAM, 0)) < 0) { printf(" Socket creation failed\n"); while(1); } addr.sin_family = AF_INET; addr.sin_port = htons(9000); addr.sin_addr.s_addr = INADDR_ANY; if ((bind(fd_listen,(struct sockaddr *)&addr, sizeof(addr))) < 0) { printf("Bind failed \n"); while(1); } if ((listen(fd_listen, 1)) < 0) { printf("Listen failed\n"); while(1); } len = sizeof(incoming_addr); FD_ZERO(&readfds); FD_SET(fd_listen, &readfds); max_socket = fd_listen+1; while(1) { printf("wait accept client\n"); select(max_socket, &readfds, NULL, NULL, NULL); if (FD_ISSET(fd_listen, &readfds)) { if((socket = accept(fd_listen, (struct sockaddr*)&incoming_addr, &len)) < 0) { printf("accept failed\n"); continue; } else { printf("accept OK\n"); int bytes_recv, nsize = 0; while((bytes_recv = recv(socket, buff, BUF_SIZE, 0)) != SOCKET_ERROR) { //printf("\n\nbytes_recv = %d\n", bytes_recv); bytes_recv = send(socket, buff, bytes_recv, 0); nsize++; printf("nsize = %d\n", nsize); } printf("\n\n\nSOCKET_ERROR\n\n\n"); } } } } TK_OBJECT(to_task); TK_ENTRY(work_server); struct inet_taskinfo server_task = { &to_task, "server", work_server, 6, APP_STACK_SIZE, }; void InitialTask(void *task_data) { alt_iniche_init(); netmain(); printf("wait inich\n"); while (!iniche_net_ready) TK_SLEEP(1); TK_NEWTASK(&server_task); OSTaskDel(OS_PRIO_SELF);// del self task while (1); } int main (int argc, char* argv, char* envp) { /* Clear the RTOS timer */ OSTimeSet(0); /* SSSInitialTask will initialize the NicheStack * TCP/IP Stack and then initialize the rest of the Simple Socket Server example * RTOS structures and tasks. */ OSTaskCreateExt(InitialTask, NULL, (void *)&InitialTaskStk, INITIAL_TASK_PRIORITY, INITIAL_TASK_PRIORITY, InitialTaskStk, TASK_STACKSIZE, NULL, 0); /* * As with all MicroC/OS-II designs, once the initial thread(s) and * associated RTOS resources are declared, we start the RTOS. That's it! */ OSStart(); while(1); /* Correct Program Flow never gets here. */ return -1; } Client code:
# include <stdio.h># include <string.h># include <winsock2.h># include <windows.h> # pragma comment(lib, "ws2_32.lib") # define PORT 9000# define SERVERADDR "192.168.0.200" //#define SERVERADDR "127.0.0.1" DWORD WINAPI RecvMess(LPVOID pmy_sock); # define COUNT_DATA 256 // 10240 &#1087;&#1086; 1024 = 10 Mb# define NN 1024 // size buffer int ready = 1; int main(int argc, char* argv) { DWORD thID; char buff; printf("TCP DEMO CLIENT\n"); if (WSAStartup(0x202,(WSADATA *)&buff)) { printf("WSAStart error %d\n", WSAGetLastError()); return -1; } SOCKET my_sock; my_sock = socket(AF_INET,SOCK_STREAM,0); if (my_sock < 0) { printf("Socket() error %d\n",WSAGetLastError()); return -1; } sockaddr_in dest_addr; dest_addr.sin_family=AF_INET; dest_addr.sin_port=htons(PORT); if (inet_addr(SERVERADDR) != INADDR_NONE) dest_addr.sin_addr.s_addr=inet_addr(SERVERADDR); // &#1089;&#1086;&#1077;&#1076;&#1080;&#1085;&#1077;&#1085;&#1080;&#1077; if (connect(my_sock,(sockaddr *)&dest_addr, sizeof(dest_addr))) { printf("Connect error %d\n",WSAGetLastError()); WSACleanup(); fgets(buff, sizeof(buff)-1, stdin); return -1; } printf("Connect with %s successfully\n\n", SERVERADDR); CreateThread(NULL, NULL, RecvMess, &my_sock, NULL, &thID); int nsize = 0; for(int i = 0; i < NN; i++) buff = (char)(i&0xFF); DWORD time = GetTickCount(); while(nsize < COUNT_DATA) { nsize++; send(my_sock, buff, NN,0); Sleep(1); } printf("Wait recv full\n"); while(ready) Sleep(1); time = GetTickCount() - time; printf("time = %ld\n", time); fgets(buff, sizeof(buff)-1, stdin); closesocket(my_sock); WSACleanup(); return 0; } DWORD WINAPI RecvMess(LPVOID pmy_sock) { //FILE *fd; char buff; int bytes_recv; SOCKET my_sock; my_sock = *((SOCKET*) pmy_sock); /*fd = fopen("recv_file.txt", "wb"); if(fd == NULL) { printf("error fopen\n"); return 1; }*/ int nsize = 0; while(nsize < COUNT_DATA) { bytes_recv = recv(my_sock, buff, NN, 0); if (bytes_recv == SOCKET_ERROR) { printf("error recv\n"); break; } /*if(bytes_recv != fwrite(buff, sizeof(char), bytes_recv, fd)) { printf("error fwrite\n"); break; }*/ nsize++; } //fclose(fd); ready = 0; return 0; }
There is a number of reasons which can cause your application to stop.
First of all you must know if the whole application crashes or it's a matter of a single task;
use a separate tasks to toggle a signal or blink a LED in order to understand this.
Also try to keep the send queue limited. I mean, before sending more data, wait until you received a certain amount. For example, if you were transmitting 1,2,3, etc. , don't send N until you have received N - K, where K is the queue limit you choose.
If this way the system works, then you have a problem with your task stack size or with memory available for managing network packets.
I met the same problem....my program is nearly the same as you posted above.
I use DM9000A/Nichestack now,and it stop receiving packets after calling send function several times.it blocks in select function,and can't return.
can you tell me how to solve this problem?
