Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
altremote_update
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Issue resolved, i was not holding the control signals long enough for the megafunction.
I have an Altera (stratix) NDK (1s10)
I have instantiated an alt_remote update megafunction using the full_featured reference design as base.
For some strange reason , i am unable to write any parameters into the megafunction, when i try to readback i always get all Ones.
all the output PIOs from the Megafunction are declared as Rising edge in the SOPC builder
and all unused pins are tristated, configuration is set to remote but it still does not work.
Can any of the pros take a look at it and tell me whats wrong?
I have been trying this for a week but cant seem to figure out the problem!
Pretty desperate !!!! Got to submit the code in 2 days
Heres my code
IOWR_ALTERA_AVALON_PIO_DATA(READ_PARAM_BASE, 0x0);
IOWR_ALTERA_AVALON_PIO_DATA(PARAM_BASE, 0x2);
IOWR_ALTERA_AVALON_PIO_DATA(DATA_IN_BASE, 0x1);
IOWR_ALTERA_AVALON_PIO_DATA(WRITE_PARAM_BASE, 0x1);
IOWR_ALTERA_AVALON_PIO_DATA(WRITE_PARAM_BASE, 0x0);
busy = IORD_ALTERA_AVALON_PIO_DATA(BUSY_BASE);
while(busy == 1)
IOWR_ALTERA_AVALON_PIO_DATA(READ_PARAM_BASE, 0x1);
while(busy == 1)
dataout = IORD_ALTERA_AVALON_PIO_DATA(DATA_OUT_BASE);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, dataout);
regards
Pavan
Highlighted
When I need to have a read/write interface I usually have 1) An lpm_decode (enabled with cs), 2) A MUX (selected with the address bits), 3) registers enabled by the lpm_decode logic.
This simple mix allows you to do anything a PIO can plus allows you to take the functionality of many PIOs and stick them altogether implemented in their own address range.
ppk031000 if you like I can send you an example of this (it&#39;s on my home machine so email me if you want it, otherwise I&#39;ll forget).
