Hi all,
I am new for NIOS II application develoment. And I need to embed a few lines of assembly in my C code. like: # include "system.h" void main() { C code 1; _asm_("assembly 1"); C code 2; _asm_("assembly 2"); C code 3; } My question is if the Nios II SBT will automatically save the previous operation results (from registers or somewhere else) before execute the assembly. As we know it does when the system handle interrupt. But how about this sutiation? Thanks in advance if you can help.:) JayLink Copied
You need to read up how gcc does inline assembly.
Topic Options
