12603 Discussions
avalon fifoed uart - problem with baudrate setting
I am setting the baudrate as 115200 but the actual baudrtae looks to be 9600. any ideas?
i am trying to add printf to check what is happening in altera_uart.c with pr_err in altera_uart_set_termios function but not seeing any thing on the console. I have hooked the console to jtag uart.
Any ideas Please?
I am using latest 20100621 tarball without any git updates.
Do you have a CCB between your nios and your UART ?
--- Quote Start ---
--- Quote End ---
Thanks a lot for your reply. For now i don't know any thing about Clock Control Block. I will find out.
CCB mean Clock Crossing Bridge not a Clock Control Block.
Do you have a Clock Crossing Bridge between your Nios and you UART ?
I had an issue with Qsys in Quartus v11.0 generating HDL with an incorrect baud rate divisor when using the "UART (RS-232 Serial Port)" component.
This problem seems to have been fixed in v11.0 SP 1.
--- Quote Start ---
--- Quote End ---
I understand. I do not know much here. I was informed that all devices are clocked by CPU CLOCK.
--- Quote Start ---
--- Quote End ---
Looks like that.
Either IP problem or some kind of initialization problem of the core in FPGA.
I have removed my comments as I found the actual problem, it is not in earlyprintk.
The actual problem is different constant defines used at many many places of initial console code.
Now I fixed at the right place, nios.h
