Hi! In the qsys I have:
1. Clock Source 2. On-Chip Memory 3. Nios II Processor 4. System ID 5. JTAG UART 6. EPCS Serial Flash Controller 7. PIO 8. SDRAM Controller I want to use SDRAM (MT48LC4M32B2) to store instructions and data for NIOS application. In the NIOS II Processor properties reset vector is set to base address of EPCS controller. Exceptions vector is set to base address to SDRAM. In the NIOS EDS for Eclipce I can debug my application, it works. But in the NIOS flash programmer error occur: "Error: Error code: 4 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "D:/Work/QuartusProjects/tests/test2/flash/test2_epcs_flash.flash" --base=0x2003800 --epcs --sidp=0x2004010 --id=0x0 --timestamp=1359654107 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program" What I did wrong? Thank youLink Copied
- « Previous
- 1
- 2
- Next »
Could you access the EPCS from Nios? Try to write/read the EPCS with the alt_flash functions.
You could verify if the firmware was flashed correct to EPCS. The firmware follows immediately after the fpga design in the EPCS. To get the start address in EPCS look at the firmware.flash. Its similar a srec file where the first S1, S2 or S3 record contains the start address. Reading from EPCS: nios2-flash-programmer --cable='USB-Blaster [USB-0]' --epcs --base=0x21000 --read-bytes <start_address_firmware>+<size_of_nios_firmware> --read epcs.out Jens- Mark as New
I'll try to read/write the EPCS and write memory test of SDRAM. Thank you
Test of SDRAM and Flash from NIOS application is ok! I write to all bytes 0xAA then read and verify it. Then I write 0x55 and verify it. In both devices it works good. But it still don't boot from flash after power on :-(
anybody can help me?
Could you attach your project as Quartus archive (qar file)?
In the forum is a similar thead for booting from EPCS with Cyclone3
http://www.alteraforum.com/forum/showthread.php?t=6744 may you have a look ...- Mark as New
thank you, maybe I make a mistake...I don't know.
- « Previous
- 1
- 2
- Next »
