Hi~
Could you help me, thanks. The kernel image and .sof is OK. Then, when I try to download them to DE0 board I key in command "$nios2-configure-sof DE0_TOP.sof" and "$nios2-download -g zImage" They are OK. But when I key in command "$nios2-terminal" It stuck at "PID hash table entries: 32 (order: 5, 128 bytes)" It can not continue to execute ************************************************ [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.19-uc1 (root@ubuntu) (gcc version 3.4.6)# 27 PREEMPT Mon Jul 2 5 20:07:51 PDT 2011 uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. Built 1 zonelists. Total pages: 2032 Kernel command line: PID hash table entries: 32 (order: 5, 128 bytes) <--------------stop here ************************************************** ********* Could you tell me how to solve it Thank you very muchLink Copied
--- Quote Start --- Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.19-uc1 (root@ubuntu) (gcc version 3.4.6)# 27 PREEMPT Mon Jul 2 5 20:07:51 PDT 2011 --- Quote End --- This looks like a very old kernel version. Where did you get/build that from? Please follow the instructions from the Altera Wiki (http://www.alterawiki.com/wiki/linux) to get a more recent version of the Kernel and uClinux-dist
Thank you very much.
It work.- Mark as New
Sir,
i want to work with DE0 board under uclinux, myself using ubuntu 10.04, i came to know i cant get images to load under ubuntu ,is it true?, I am very knew to this ,kindly hlep me. Thanks , Alex.
