Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
booting multiple nios2 from SDRAM
Hi
Any advice..?
I have a S260ES dev board and what I want to do is have 2 nios2's boot and run from the top 2Mbytes of the installed 16Mbytes SDRAM (located at 0x0 to 0x000FFFFF).
I have 2 cpus CPU_A and CPU_B. I have a JTAG_UART for each. I have the SDRAM interface and finally some buttons and leds for stimulus and response
for CPU_A
I set the reset address to 0x00E00000 and the exception address to 0x00E20000
and for CPU_B
I set the reset address to 0x00D00000 and the exception address to 0x00D20000
I build the system and create two simple hello world projects (that poll a button and printf hello world) each with seperate system libraries.
For both projects I set the system library .text .rodata and .rwdata options to SDRAM
stdin/out and err to the correct JTAG UART
When I run (debug) the projects seperately.. they both work fine.
But when I run them concurrently only one (the last one started) will run!
I guess im doing something obvious wrong..!?!
Cheers in advance for any help
kits version??
I think:
if verison is v1.0, change the tcp port in debug configuration page,so that the two projects have different tcp ports.
if verison is v1.1, create a multiprocessor collection and include the two projects.
Hi Cheers for the reply..
Im using 4.1 and 1.0.. I had set the tcp ports to be different..!
What I think I had done wrong was I only had one system timer and was tring to use this for
both processors.. Duh!!
(one would clear the interrupt and the other would hang waiting for it!!)
I have just got copies of 4.2 and 1.1.. im going to have a play today to see what improvements
there are w.r.t multi-proc systems
(I actually have 7 niosII's in my design so im hopping it will make things a little easier.)
