12435 Discussions
bsp-generate-files SEVERE: null
Thanks in advance. I know that I have done this command before and it has generated the "uboot" directory. But now I'm working on another project (just the GHRD for the Sodia Eval board) to embed to the QSPI and I get an error (see below).
My steps before this command were:
1. Use the GHRD for 16.1 for the Sodia - but utilize Q 17.0 - so I a) generate in QSYS b) recompile
2. Use the bsp-editor to specify that I want to boot from QSPI and generate
3. Start up the embedded-command-shell and
a) bsp-create-settings --preloader-settings-dir=hps_isw_handoff/soc_system_hps_0 --type=uboot --settings=software/settings.bsp
b) bsp-update-settings --settings=software/settings.bsp --set uboot.boot_device QSPI
THEN --> when I do the "bsp-generate-files" there is the error.
WHAT AM I MISSING ??
bsp-generate-files --settings=software/settings.bsp --bsp-dir=software/uboot
q16@nxp-System-Product-Name:~/SODIA/Q17.0-withGHRD-16.1/sodia_ghrd_v16.1.0$ bsp-generate-files --settings=software/settings.bsp --bsp-dir=software/uboot
INFO: Generating BSP files...
INFO: nios2-bsp-generate-files --settings software/settings.bsp --bsp-dir software/uboot
INFO: Initializing BSP components...
INFO: Finished initializing BSP components. Total time taken = 2 seconds
INFO: Searching for BSP components with category: os_software_element
INFO: Searching for BSP components with category: driver_element
INFO: Searching for BSP components with category: software_package_element
INFO: Generating BSP files in "/home/q16/SODIA/Q17.0-withGHRD-16.1/sodia_ghrd_v16.1.0/software/uboot"
INFO: Generated file "/home/q16/SODIA/Q17.0-withGHRD-16.1/sodia_ghrd_v16.1.0/software/settings.bsp"
SEVERE: null
java.lang.NullPointerException
at com.altera.embeddedsw.utils.MemoryMapUtils.getMemoryMap(MemoryMapUtils.java:32)
at com.altera.embeddedsw.bsp.core.internal.generator.device_tree.DeviceTreeImporter.importModel(DeviceTreeImporter.java:44)
at com.altera.embeddedsw.bsp.core.internal.generator.device_tree.DeviceTreeGenerator.importPhase(DeviceTreeGenerator.java:50)
at com.altera.embeddedsw.bsp.AbstractBsp.generate(AbstractBsp.java:1367)
at com.altera.embeddedsw.commandline.bsp.BspGenerateFilesCommand.execute(BspGenerateFilesCommand.java:92)
at com.altera.embeddedsw.utilities.commandline.AbstractBuildCommandLine.executeCommand(AbstractBuildCommandLine.java:150)
at com.altera.embeddedsw.commandline.bsp.BspGenerateFilesCommand.main(BspGenerateFilesCommand.java:118)
SEVERE: nios2-bsp-generate-files failed.
O.K. Even though I got those errors I did the following:
cd software/spl_bsp
make uboot
and compiled the u-boot image !!
SUCCESS -- but the error above really is confusing...
SOLVED
