hi. i am a beginner on uclinux and i followed the UClinuxDist to build the uclinux kernel, but it turned out some errors.
********************************************************** >make vendor_hwselect SYSPTF=~/download/HW/system_0.ptf ............. >make romfs ........ make[1]: Leaving directory `/home/echo/download/uClinux-dist/lib' make[1]: Entering directory `/home/echo/download/uClinux-dist/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/home/echo/download/uClinux-dist/include' make[1]: Entering directory `/home/echo/download/uClinux-dist/user' for i in boa busybox cgi_generic dhcpcd-new ftp ftpd games inetd init ntp sash telnetd /home/echo/download/uClinux-dist/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/home/echo/download/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entering directory `/home/echo/download/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: can't confirm ‘boa’: No such file or directory make[3]: *** [romfs] error 1 make[3]: Leaving directory `/home/echo/download/uClinux-dist/user/boa/src' make[2]: *** [romfs] error 2 make[2]: Leaving directory `/home/echo/download/uClinux-dist/user/boa' make[1]: *** [romfs] error 2 make[1]: Leaving directory `/home/echo/download/uClinux-dist/user' make: *** [romfs.subdirs] error 1 >make ...... CHK include/linux/version.h CHK include/linux/utsrelease.h CHK include/linux/compile.h GEN usr/initramfs_data.cpio.gz /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found Unrecognized dir format '/init 777 1000 1000' line 42 make[2]: *** [usr/initramfs_data.cpio.gz] error 255 make[1]: *** [usr] error 2 make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x' make: *** [linux] error 1 >make ............ /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found Unrecognized dir format '/init 777 1000 1000' line 42 make[2]: *** [usr/initramfs_data.cpio.gz] error 255 make[1]: *** [usr] error 2 make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x' make: *** [linux] error 1 >make linux image ............. make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1 no emulation specific options. make[1]: Entering directory `/home/echo/download/uClinux-dist/linux-2.6.x' CHK include/nios2_system.h perl -I/home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < /home/echo/download/HW/system_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi CHK include/linux/version.h CHK include/linux/utsrelease.h CHK include/linux/compile.h GEN usr/initramfs_data.cpio.gz /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found Unrecognized dir format '/init 777 1000 1000' line 42 make[2]: *** [usr/initramfs_data.cpio.gz] error 255 make[1]: *** [usr] error 2 make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x' make: *** [linux] error 1 ******************************************************************************** ************* my ptf is from the wiki "system_0.ptf" and seclet Altera, nios2nommu, None Libc and default all settings, i did it step by step and i don't know why these errors happen and also don't know how to solve them. so can any body help me?i will show great appreciation to you! thanks!Link Copied
Check if you have the "gawk" command with,
which gawk Or check if you have it in /usr/bin or /bin dir. Which Linux distro do you use? have you installed devolopment packages? If you are new to Linux, I would suggest CentOS 4.4.- Mark as New
--- Quote Start --- originally posted by hippo@Apr 4 2007, 09:28 AM check if you have the "gawk" command with,
which gawk
or check if you have it in /usr/bin or /bin dir.
which linux distro do you use? have you installed devolopment packages?
if you are new to linux, i would suggest centos 4.4.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22799)
--- quote end ---
--- Quote End --- i run the command "gawk --help", the terminal shows"command not found", and i have checked that there was no "gawk" in both /bin and /usr/bin dir. i use ubuntu6.1 linux . just now i build kernel again, but run "make romfs" after running "make", and finally i got the zImage file ,but there were still many problems as follows(after i run "make linux image") : ********************** /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found /home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found Unrecognized dir format '/bin/cp 777 1000 1000' line 9 Unrecognized dir format '/bin/dd 777 1000 1000' line 10 Unrecognized dir format '/bin/mount 777 1000 1000' line 11 Unrecognized dir format '/bin/netstat 777 1000 1000' line 12 Unrecognized dir format '/bin/ping 777 1000 1000' line 13 Unrecognized dir format '/bin/rm 777 1000 1000' line 14 Unrecognized dir format '/usr/bin/ftpget 777 1000 1000' line 59 Unrecognized dir format '/usr/bin/ftpput 777 1000 1000' line 60 Unrecognized dir format '/usr/bin/telnet 777 1000 1000' line 61 Unrecognized dir format '/usr/bin/wget 777 1000 1000' line 62 Unrecognized dir format '/init 777 1000 1000' line 66 Unrecognized dir format '/sbin/ifconfig 777 1000 1000' line 68 Unrecognized dir format '/sbin/insmod 777 1000 1000' line 69 Unrecognized dir format '/sbin/lsmod 777 1000 1000' line 70 Unrecognized dir format '/sbin/modprobe 777 1000 1000' line 71 Unrecognized dir format '/sbin/rmmod 777 1000 1000' line 72 Unrecognized dir format '/sbin/route 777 1000 1000' line 73 make[2]: *** [usr/initramfs_data.cpio.gz] error 255 make[1]: *** [usr] error 2 make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x' make: *** [linux] error 1 *********************************
You need gawk package, follow
https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html (https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html) If you are new to Linux, you should try CentOS 4.4 (but not 5.x) . Select the development tool package group, everything should be here.- Mark as New
--- Quote Start --- originally posted by hippo@Apr 4 2007, 08:53 PM you need gawk package, follow
if you are new to linux, you should try centos 4.4 (but not 5.x) . select the development tool package group, everything should be here.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22820)
--- quote end ---
--- Quote End --- thanks, hippo. i have solved it! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
--- Quote Start --- originally posted by hippo@Apr 4 2007, 10:28 AM check if you have the "gawk" command with,
which gawk
--- quote end ---
--- Quote End --- I have it in /usr/bin dir, but when i make romfs: make[2]: Entering directory `/home/nios/download/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entering directory `/home/nios/download/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: stat‘boa’失败: 没有那个文件或目录 make[3]: *** [romfs] 错误 1 make[3]: Leaving directory `/home/nios/download/uClinux-dist/user/boa/src' make[2]: *** [romfs] 错误 2 make[2]: Leaving directory `/home/nios/download/uClinux-dist/user/boa' make[1]: *** [romfs] 错误 2 make[1]: Leaving directory `/home/nios/download/uClinux-dist/user' make: *** [romfs.subdirs] 错误 1
Topic Options
