Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
building Kernel fails
Hi @ all,
I have updated the Nios to version 1.1 and the Linux Distribution to version 1.3..
The OpenCore Ethernet MAC is included in this Project and was running in the older versions of the Nios and Linux.
Now I'm trying to build the Kernel and the C_Build flow looks like the following:
Microtronix Linux Extensions
Version 1.2, Built Wed Jul 27 3:46pm EST 2004
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
no emulation specific options.
Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel
CHK include/linux/version.h
CHK include/nios2_system.h
Could not execute ...scripts/nios2_system.h/OpenCores_Ethernet_MAC.pm
Error message follows:
Undefined subroutine &OpenCores_Ethernet_MAC::run called at (eval 4) line 1, <STDIN> line 3946.
The Nios2_system.h is created with this two warnings:
/* Executing ...scripts/nios2_system.h/OpenCores_Ethernet_MAC.pm */# warning Could not execute ...scripts/nios2_system.h/OpenCores_Ethernet_MAC.pm# warning Error message is stored in nios2_system.h:
Has anyboby an idea was going wrong ?
