cache not enable
Dear all,
I have some questions about the U-boot. The hardware board is designed by myself. The SoC is 10AS016E4F27E3SG.
I run the Bootloader on the board and print the following information:
U-Boot 2014.10 (Apr 20 2018 - 13:44:44)
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C: ready
DRAM: WARNING: Caches not enabled
SOCFPGA DWMMC: 0
FPGA: writing output_file.rbf ...
Full Configuration Succeeded.
emif_reset interrupt acknowledged
Error: Could Not Calibrate SDRAM
DDRCAL: Failed
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe386e8
DRAM : 0 Bytes
data abort
pc : [<ffe001cc>] lr : [<ffe024cd>]
sp : ffe3fff0 ip : 00000016 fp : 00000001
r10: ffd02078 r9 : ffe38ee8 r8 : ffe00000
r7 : ffe20444 r6 : 00000000 r5 : 00000000 r4 : ffeff000
r3 : ffe38faf r2 : ffe40000 r1 : ffe3b000 r0 : ffe38ee8
Flags: nzcv IRQs on FIQs on Mode SVC_32
Resetting CPU ...
resetting ...
Why is the cache not enabled?
I'm not sure not having the cache enable at such an early point in the boot process is really a problem. I think the real problem is the SDRAM calibration that failed. You can compile a new version of the preloader wich will give you more output on the calibration process and where it fails, by changing the RUNTIME_CAL_REPORT to 1 in uboot-socfpga/board/altera/socfpga/sdram/sequencer_defines.h and recompiling it.
Have a look at https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/external-memory/emi_ip.pdf sections 17.4 and 17.5 for more information on how to debug calibration failures.
Thank you very much for your reply.I changed RUNTIME_CAL_REPORT to 1 according to your method&#65292;but I could not also calibrate SDRAM.The error message is consistent.I found that I didn't place the PLL reference clock pin in the address/command bank.Through the reference design I found that the PLL-ref-clock should be a differential clock,but I didn't connect the differential clock outside BANK 2K( address/command bank).Is this the reason twhy I can't calibrate DDR?In this case, what suggestions can be set to generate pll_ref_clk clock, so as to achieve the DDR3 read and write control.
TSege1
I am also have the same problem with emif_reset message on Arria 10 U-boot with DDR4
I also  changed RUNTIME_CAL_REPORT to 1, and i dont see debug printing.
 did you managed to get the debug printing on U-boot?
can you advice?
Thanks!
