12603 Discussions
can't generate nios II .sof file
hi everyone..i try to connect my program to the board but unfortunately this kind of error was popup
"No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded."
what should i do right now..?:confused::confused:
Firstly, is your usb blaster working? Can check if the jtag connection is working at the Quartus II Programmer.
Secondly, have you successfully run full compilation in Quartus and downloaded the .sof file into your board?
firstly, sorry for the late reply and thanks for your answer forum_newbie...now i can generate the .sof file already..but im facing the new problem right now which is the ELF process downloading failed...what should i do to solve this problem?can you help me?because i already try a lot of solution to confront this problem by looking for previous forum but i still didnt get the solution..
Is your pins being assigned correctly especially you reset pin? The other thing you can check is the Nios II debug reset request. Is it connected to the jtag reset port?
thanks forum_newbie for the answer..the pin already assigned correctly...but the problem still occur..where can i find the nios ii debug rest request because im really blur about that...and for your information i use nios II/e version because i dont have the license..is it this version of nios make the "elf process downloading failed" occur? and if i use nios II/f..is it the problem can solve?
Hello Bittersweet,
I wrote a large post about pitfalls I fell into when trying to get Nios/e operational.
You might want to look at "Read/Write data to SDRAM on DE0 nano using NIOS ii"
Johi.
Which version of Quartus are you using? And can you provide me your design for me to take a look at it?
