12600 Discussions
change the clock frequency of the USB-Blaster II download cable
Hi everyone,
I wanna change the clock frequency of the USB-Blaster II download cable from 24MHz to 6MHz and I saw they said we have to use the command:
jtagconfig --setparam <cable> JtagClock <frequency>
but could someone tell me what should i do exactly?
Because when i try it in the terminal, it shows me jtagconfig --setparam 1 JtagClockThMjtagconfig: command not foundEven when i try to use that command sudo apt-get install jtagconfig
[sudo] password for jiang:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package jtagconfig
Thank you in advance
Hi!
jtagconfig it's located in <quartus-intallation-path>/bin/ . Move to this folder and then run ./jtagconfig. Be sure that jtagd is running.
