configure kernel fails
when i want to configure my kernel in the drop down menu, the window opens shortly and closes a second later. normally opens the blue configuration window, but here only the bash window for just a moment. i tried it with different kernels, it's always the same.
knows someone this problem????
thx
That's a known problem... could've sworn there was a thread about this earlier that I could point you to. Anyhoo...
The only tested and true method of debugging this issue is:
(1) modify the configure.bat file in your kernel project within the Nios II IDE
(2) remove the @start from the beginning of the line in the batch file
(3) open up a regular command prompt (not a Nios II SDK Shell)
(3a) run cd ...altera\kits\nios2\bin\eclipse\workspace\<kernel project>
(3b) run configure.bat
You should now be able to view the error messages.
Common issues:
gcc or nios2-elf-gcc not found...
... you may need to run SOPC Builder at least once in order for your Quartus II/SOPC Builder installation to be complete. After running SOPC Builder, try configuring the kernel again
crt0.o not found...
... this is trickier, you need to double check that a crt0.o file exists within the ...quartus/bin/cygwin/usr/lib directory. This is the one that the kernel configuration is trying to link against. If it&#39;s there then something is different about your mount points than what we expect it to be. We typically unmount the current /usr/lib if it&#39;s mounted, so you may try that from the Nios II SDK Shell before attempting to configure your kernel again.
any other error messages, let me know...
I&#39;ve had a similar problem on a system on which a standalone copy of Cygwin was installed. I&#39;m guessing that the uClinux installer found Cygwin and not Quartus&#39; Cygwin, which led to some kind of problem finding gcc. I couldn&#39;t get Cygwin and Quartus Cygwin to coexist, so I uninstalled Cygwin, reinstalled uClinux, and it all worked.
If the installer asks you for the location of Cygwin, make sure you point it to Quartus II 4.0&#39;s Cygwin.
hi, can somebody tell me the correct command for umount the stuff.
thx
no sorry i&#39;ve got another problem
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.
microtronix.nios2linux.kernel_0.1.5/linux-2.6.x&#39;
HOSTCC scripts/basic/fixdep
gcc: not found
make[2]: *** [scripts/basic/fixdep] Error 127
make[1]: *** [scripts_basic] Error 2
make: *** [menuconfig] Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.m
does anyone know something about this error!!
the gcc does exist!!
thx
