Hii,
i have hdl coder in matlab v2011. when a matlab file is converted into C language file then its giving errors. what is the procedure to generate C program successfully in nios after converting from matlab code. can anyone help me in converting a matlab code to C/C++ code so that i could be generated on nios2 and compiled on altera de1 board. thanks. regards.Link Copied
