12600 Discussions
create software for Altere PIO 's
this is my code below,
its self explanatory, i am unable to get the IOWR_ALTERA_AVALON_PIO_SET_BITS(base) to work as the output is confirming it. My PIO is set to 1
# define ALT_MODULE_CLASS_GPIO_0 altera_avalon_pio
# define GPIO_0_BIT_MODIFYING_OUTPUT_REGISTER 1
CODE:::
# include <stdio.h>
# include <unistd.h>
# include "altera_avalon_pio_regs.h"
# include "system.h"
# include <strings.h>
// Time in microseconds to wait for switch debounce
int main(void)
printf("Simple\n"); // print a message to show that program is running
int data1 = 0x00000309;
int val,val2;
//while(1){
IOWR_ALTERA_AVALON_PIO_DATA(GPIO_0_BASE,data1);
val = IORD_ALTERA_AVALON_PIO_DATA(GPIO_0_BASE);
printf("previous value = %x \n",val);
IOWR_ALTERA_AVALON_PIO_SET_BITS(GPIO_0_BASE+4, 0x02);
val2 =IORD_ALTERA_AVALON_PIO_DATA(GPIO_0_BASE);
printf("value after setting the bit = %x " , val2);
-----------------OUTPUT------------------
Simple
previous value = 309
value after setting the bit = 309
You shouldn't call IOWR_ALTERA_AVALON_PIO_SET_BITS with an Offset, as the offset is already added inside the Macro.
Thanks for your help
I got this working
# include <stdio.h>
int main(void){
int val;
//IOWR_ALTERA_AVALON_PIO_DATA(GPIO_1_BASE,0x0000);
//printf( " GPIO default values are set at 0 \n");
IOWR_ALTERA_AVALON_PIO_SET_BITS(GPIO_1_BASE,0x0003);
val = IORD_ALTERA_AVALON_PIO_DATA(GPIO_1_BASE);
IOWR_ALTERA_AVALON_PIO_DATA(LEDR_BASE, val);
usleep(10000000);
IOWR_ALTERA_AVALON_PIO_CLEAR_BITS(GPIO_1_BASE, 0x0001);
//set latch
//printf(" GPIO 1st bit set to 1\n");
// IOWR_ALTERA_AVALON_PIO_CLEAR_BITS(GPIO_0_BASE,0x1000);//oe enable
// IOWR_ALTERA_AVALON_PIO_CLEAR_BITS(GPIO_0_BASE,0x200);//clear latch
What's the advantage of using this approach instead of the IOWR_32DIRECT and IORD_32DIRECT?
(or just IOWR and IORD_
Readability.
Hmmm... IMHO any code that uses any of the IOWR* defines is inherently unreadable and difficult to maintain.
In this case you are also forcing 3 io/memory cycles when (probably) 2 are needed.
I'd also tend to recommend using 'write 1 to set' and 'write 1 to clear' registers for general pio in order to remove the need for read-modify-write cycles on shared resources (save the need to disable interrupts).
--- Quote Start ---
Readability.
--- Quote End ---
Nice comment!
Seriously can we have smaller, readable not-all capitals macros please.
