12469 Discussions
creating Nios program, loading, booting ...
I have successfully got Linux up & running with my Atlas(de0-nano-soc) board - application works , yada yada yada ...
- but would like to offload some processing from the Arm(s) - to a NIOS sub processor
essentially hold the NIOS in reset - upload code (from linux ) - release NIOS (boot)
- I have read over an458.pdf (alternate boot methods) & examined the code -
but am still at a loss of how to produce file with a obvious NIOS entry point ?
should i be using an .elf ? sof ?
my code is quite small - is the nios environment really the best way ?
(test program is only 3 lines, proved ARM code is ~100 lines)
any ideas ? links ? or code ?
back to replying to my own threads ...
nios2-elf-objcopy is what i needed ...
