dm9000 device tree
Can someone give me some instructions, howto get dm9000a Ethernet card to work with latest nios2 linux community edition (kernel 3.3.0-rc7) with device tree? My development board is DE2-70
I tried to generate the device tree structure with sopc2dts utility and I got this message "Component DM9000A of class DM9000A_IF is unknown"
so I edited the dm9000 section in dts file to
DM9000A: ethernet@0x940a180 {
compatible = "davicom,dm9000";
reg = < 0x0940A180 0x00000008 >;
interrupt-parent = < &cpu >;
interrupts = < 5 >;
}; //end unknown@0x940a180 (DM9000A)
And added DM9000A support into kernel,
the driver is loaded, but it doesnt recognize the dm9000 card
io scheduler cfq registered (default)
ttyJ0 at MMIO 0x4001020 (irq = 1) is a Altera JTAG UART
console [ttyJ0] enabled, bootconsole disabled
dm9000 Ethernet Driver, V1.31
mousedev: PS/2 mouse device common for all mice
TCP cubic registered
I tried it before with older version, configured with ptf file and it worked good, but with the newer version I cannot get it up.
Any help would be appreciated
Thank You
What is the version you are developing with?
See that:
In the Nios II v9.0 or later, the TCP/IP includes the networking stack of the Nichstack, however, the DE2_NET project was built on the LWIP. The driver for the DM9000A should be different in the Nichstack to the LWIP. Then, if you want to migrate the DE2_Net project to Nios II v11.1, you have to create a new driver for the DM9000A at first.
