in ubuntu
in uclinux_dist directory make vendor_hwselect SYSPTF=/usr/local/src/nios_system.ptf first time type this command, do not connect blast usb of DE2-115 board when i do not know need it when i meet this option, i plug in the blast usb and select this usb in virtual box and run above command again, it still do not have this option then i make clean and run the above command again, it still do not have this option do i need to make menuconfig again and run above command again? do i need to install quartus 14 which i failed to install ? do not have cfi_flash_0 which listed in tutorial example web --- Please select which CPU you wish to build the kernel against: (1) cpu_0 - Class: altera_nios2 Type: f Version: 7.071 Selection: 1 --- Please select a device to upload the kernel to: (1) cfi_flash_0 Class: altera_avalon_cfi_flash Size: 4194304 bytesLink Copied
Topic Options
