dtb generation
Hi community,
I want to modify my devicetreeblob-file. After weeks of searching the web, I now know how to generate this dtb (http://www.rocketboards.org/foswiki/documentation/gsrd141devicetreegenerator).
But I do not know how to modify it.
I am trying to bring up two tse-interfaces (http://rocketboards.org/foswiki/projects/alterasoctriplespeedethernetdesignexample).
I have installed Quartus V14.1 including all addons.
Linux is built in a virtual machine, running ubuntu 12.04 LTS.
what works:
Linux is booting and does load the "altera_tse" driver.
what does not work:
Linux / the driver does not fully recognise the two interfaces.
On boot up the error-message shows up: altera_tse c0010000.ethernet: resource s1 not defined
(c0010000 is the base address of my first tse, the same error shows up for the second tse-interface)
If I list my brought up interfaces with "ip addr", they are not listed.
My questions:
1. What do I have to write into the xml files, so Linux/ the driver will recognise the tse-interfaces?
2. If I would add other IP-Cores to the FPGA, where would I get the information about what to add to the xml-files?
Thanks in advance,
Fabian
