12600 Discussions
eclipse does not start from Quartus
nome
Hello
I am using quartus 22.1 Linux Ubuntu X64 when we start nios ecilpse from Quartus IDE it will not start
Maybe we have to add environment variable in .bashrc
please help us
Nome
EBERLAZARE_I_Intel
I'm guessing you're talking about the Nios II Software Build Tools, from ver 19.1 onwards we need to manually install the Eclipse IDE components:
https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/installing-eclipse-ide-into-eds.html
You may follow above steps and it should be straightforward, let me know if you need further help on the installation.
nome
Hello
I checked our installation directory's nios 2 and ecilpse is already installed there but when i run ecilpse from Quartus nothing start anything
maybe it environment variable issued
OR maybe intel Altera doesn't support directly start ecilpse for new Quartus version
EBERLAZARE_I_Intel
I see, could you try running an Nios II command shell, and open the eclipse from the command shell. Does that work?
nome
Hello
Yes i checked by using shell command it's working but some icon doesn't show properly
Nome
EBERLAZARE_I_Intel
Just to confirm, have you run the installation steps below manually?
EBERLAZARE_I_Intel
Any update from your side?
nome
Hello
it was a python3 environment issue and I export two different variables
now issued has solved
everything  working good
Nome
EBERLAZARE_I_Intel
Apologies for the late update, I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
MarcoWu
Hi sir:
Could you please to share the mothed you fixed the problem?
Best regards
Marco Wu
