Hello people,
Im having problems to start eclipse-nios2 on Opensuse 13.2, using quartus 13.1. Always i try call eclipse-nios2 from my laptop it only load INDIGO eclipse and dont show any perspective NIOS II. Here a log contain a debug from NIOS: # ./eclipse-nios2 -Debug Start VM: /home/REDBEAR/altera/13.1/quartus//linux/jre/bin/java -Dosgi.requiredJavaVersion=1.5 -XX:MaxPermSize=256m -Xms40m -Xmx384m -Dosgi.user.area=@user.home/.altera.sbt4e/13.1.0.162 -Dosgi.configuration.area=@user.home/.altera.sbt4e/13.1.0.162/configuration -Dosgi.configuration.cascaded=true -Dosgi.instance.area.default=@user.home/sbt4e-13.1-workspace -jar /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -arch x86 -showsplash -launcher /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/eclipse -name Eclipse --launcher.library /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505/eclipse_1407.so -startup /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideVmargs -exitdata 1c98004 -product org.eclipse.epp.package.cpp.product -Debug -perspective com.altera.sbtgui.ui.cPerspective -vm /home/REDBEAR/altera/13.1/quartus//linux/jre/bin/java -vmargs -Dosgi.requiredJavaVersion=1.5 -XX:MaxPermSize=256m -Xms40m -Xmx384m -Dosgi.user.area=@user.home/.altera.sbt4e/13.1.0.162 -Dosgi.configuration.area=@user.home/.altera.sbt4e/13.1.0.162/configuration -Dosgi.configuration.cascaded=true -Dosgi.instance.area.default=@user.home/sbt4e-13.1-workspace -jar /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar Configuration location: file:/home/REDBEAR/.altera.sbt4e/13.1.0.162/configuration/ Configuration file: file:/home/REDBEAR/.altera.sbt4e/13.1.0.162/configuration/config.ini loaded Install location: file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/ Configuration file: file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/configuration/config.ini loaded Shared configuration location: file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/configuration/ Framework located: file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar Framework classpath: file:/home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar Splash location: /home/REDBEAR/altera/13.1/nios2eds/bin/eclipse_nios2/plugins/org.eclipse.platform_3.7.2.v201202080800/splash.bmp Debug options: file:/home/REDBEAR/altera/13.1/nios2eds/bin/.options not found Time to load bundles: 11 Starting application: 3103 Application Started: 12503# Any help could be very good.Link Copied
