I'm using Quartus II standard 20.1. I have a simple system designed using Platform designer that incorporates standard stuff (Nios II, PLL, RAM, on-chip flash etc). I intend to execute code from the on-chip flash (UFM single uncompressed).
When I try to configure hal.linker via the BSP editor I can enable all the required settings (enable_alt_load, enable_alt_load_copy_ro_data, enable_alt_load_copy_rwdata, etc) if I set the operating system to Altera HAL.
If instead, I set the operating system to Micrium uc/OS-II then these options are disabled for some reason.
Screenshots attached.
Is this intended? Or am I doing something wrong?
Hi Barry!
Thanks for reaching us.
Is the operative System you're using Windows or Ubuntu to implement your design on Quartus and eclipse?
I did the test with Quartus 20.1 installed on Windows machine and the options aren't disabled after selecting Micrium MicroC/OS-II.
could you tell me which OS you are working with?
Thanks for the reply. I'm running Ubuntu 18.04 in a VM on MacOS. Everything else is working perfectly (including the USB blaster - I have completed a few projects using this set-up). I've tried configuring the BSP a few times with fresh projects and always get the same result.
It is interesting that the moment I remove OS2 from the BSP, those alt_load functions become available again.
It is also interesting Is there anything else I can try? A different configuration for example?
Just FYI, I do appear to be able to edit the settings.bsp file in a text editor and change the 'enabled' tags to true by hand. (see below) However, I can't tell as of yet whether this change has resulted in the correct bsp being generated.
<Setting>
<SettingName>hal.linker.enable_alt_load_copy_rodata</SettingName>
<Identifier>none</Identifier>
<Type>Boolean</Type>
<Value>0</Value>
<DefaultValue>0</DefaultValue>
<DestinationFile>none</DestinationFile>
<Description>Causes the alt_load() facility to copy the .rodata section. If true, this setting defines the macro ALT_LOAD_COPY_RODATA in linker.h.</Description>
<Restrictions>none</Restrictions>
<Enabled>true</Enabled>
<Group xsi:nil="true" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
</Setting>
Hi Barry,
I've been trying to reproduce your issue but I haven't had any success.
in the tests I made, the alt_load functions never got disable.
Would you mind to share your *.sopcinfo file with me to see exactly the way you have configured it and then reproduce the issue?
Thanks in advance,
-Eliath Guzman
