12603 Discussions
failed to execute :wsl dos2unix create-this-bsp; ./create-this-bsp --cpu-name nio2_gen2_0 --no -make
venkatasateesh
i have tried whatever solutions posted in google and forums as shown below,
1.https://docs.microsoft.com/en-us/windows/wsl/install-win10
2.a. sudo apt-get update
 b. sudo apt install wsl
 c. sudo apt install dos2unix
 d. sudo apt install make
my windows version is  21h1(os build 19043.1320) the issue is still occuring ,could anyone tell exact reason solution.
                                                       i am looking forward for your response
Thanks&Regards
sateesh
EBERLAZARE_I_Intel
If you have install correctly and still the error persists, can you check below discussion to probably solve the issue:
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/dos2unix-fails-to-change-permissions-when-creating-project-from/td-p/1193060
