Thanks in advance.
I've got a custom embedded uClinux NIOS system with a compact flash (I use ext3). The system records *.bin files and we extract them via ftp using "mget." After a few files I get 425 Can't open passive connection: Cannot assign requested address. Passive mode refused. Turning off passive mode. I have used the 2c35 evaluation board to recreate the problem AND do ftp with debug on. I higlighted the output problem with "italics" It appears that the CLIENT gets confused and tries to open the port using IT'S ip address. I did some googling and am basically don't have any good ideas how I can prevent this problem. Any solutions, things to try, ... WOULD BE GREATLY APPRECITED. ****************************************** FTP Session Linux client to Evaluation Board (same FTP server). With DEBUG VERBOSE (-dv) enabled (NOTE: apwr is set in my Network stuff so I don't have to type 129.131.7.220 all the time). Also the IP address of the Linux machine I was running the client upon was 129.131.7.14. TRIED WITH WINDOW ftp client and same story ... **************************************************************************** [janet@localhost ~]$ ftp -dv apwr Connected to AARGMpwr. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. ftp: setsockopt: Bad file descriptor ---> AUTH GSSAPI 500 'AUTH GSSAPI': command not understood. ---> AUTH KERBEROS_V4 500 'AUTH KERBEROS_V4': command not understood. KERBEROS_V4 rejected as an authentication type Name (apwr:janet): ftp ---> USER ftp 331 Guest login ok, type your name as password. Password: ---> PASS XXXX 230 Guest login ok, access restrictions apply. cmds.c:276: verbose=2 debug=1 overbose=2 ---> SYST 215 UNIX Type: L8 Version: uClinux 2.6.30 Remote system type is UNIX. Using binary mode to transfer files. ftp> ls ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,160,219) ---> LIST 150 Opening ASCII mode data connection for '/bin/ls'. 226 Transfer complete. ftp> passive Passive mode off. ftp> passive Passive mode on. ftp> mget *.bin ftp: setsockopt (ignored): Permission denied ---> PASV ---> NLST *.bin mget PWR_01-01-00-00.01.18.bin? y ---> TYPE I 200 Type set to I. ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,184,190) ---> RETR PWR_01-01-00-00.01.18.bin 150 Opening BINARY mode data connection for 'PWR_01-01-00-00.01.18.bin' (43657216 bytes). 226 Transfer complete. 43657216 bytes received in 47 seconds (9.1e+02 Kbytes/s) mget PWR_01-01-00-00.02.40.bin? y ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,176,103) ---> RETR PWR_01-01-00-00.02.40.bin 150 Opening BINARY mode data connection for 'PWR_01-01-00-00.02.40.bin' (1232896 bytes). 226 Transfer complete. 1232896 bytes received in 1.4 seconds (8.4e+02 Kbytes/s) mget PWR_01-01-00-00.02.41.bin? y ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,219,122) ---> RETR PWR_01-01-00-00.02.41.bin 150 Opening BINARY mode data connection for 'PWR_01-01-00-00.02.41.bin' (10937344 bytes). 226 Transfer complete. 11175936 bytes received in 15 seconds (7.3e+02 Kbytes/s) mget PWR_01-01-00-00.03.18.bin? y ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,179,173) ---> RETR PWR_01-01-00-00.03.18.bin 150 Opening BINARY mode data connection for 'PWR_01-01-00-00.03.18.bin' (4663296 bytes). 226 Transfer complete. 4663296 bytes received in 5.1 seconds (8.9e+02 Kbytes/s) mget PWR_01-01-00-00.06.23.bin? y ftp: setsockopt (ignored): Permission denied ---> PASV 227 Entering Passive Mode (129,131,7,220,229,249) ---> RETR PWR_01-01-00-00.06.23.bin 150 Opening BINARY mode data connection for 'PWR_01-01-00-00.06.23.bin' (23447552 bytes). 226 Transfer complete. 23447552 bytes received in 25 seconds (9e+02 Kbytes/s) mget PWR_07-14-11-17.20.13.bin? y ftp: setsockopt (ignored): Permission denied ---> PASV 425 Can't open passive connection: Cannot assign requested address. Passive mode refused. Turning off passive mode. ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,220,164 500 Illegal PORT Command ftp: bind: Address already in use mget PWR_07-14-11-21.02.42.bin? y ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,207,36 500 Illegal PORT Command mget PWR_07-14-11-21.03.25.bin? y ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,229,98 500 Illegal PORT Command mget PWR_07-15-11-15.22.29.bin? y ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,164,234 500 Illegal PORT Command mget PWR_07-15-11-16.02.54.bin? y ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,172,37 500 Illegal PORT Command mget PWR_07-15-11-16.14.25.bin? y ftp: setsockopt (ignored): Permission denied ---> port 129,131,7,14,186,147 500 Illegal PORT Command mget PWR_07-15-11-16.21.58.bin? n mget PWR_07-15-11-22.35.36.bin? n ftp> quit ---> QUIT 221 Goodbye. [janet@localhost ~]$Link Copied
I don't know exactly what you did to get these messages
---> AUTH GSSAPI
but they probably has something do with this problem. And there is also the problem that you didn't login with the right acount. You just used the "guest" account which is not able to your commands. So try to use the "root"-account from you uClinux board when logging in.
Urmel (and anyone else),
What you have commented upon has nothing to do with my problem. When you use NIOS2 with uClinux you typically use GUEST ftp login. "ftp" with no password and you can only work in "/home/ftp" defined in "passwd" So I changed the "passwd" file to point to my compact flash. so i am logged on properly and i can transfer files for awhile. MORE INFORMATION -- I added a user in "passwd" and loggeed on to FTP as a user so that the FTP transactions WERE NOT as a GUEST and I still get the same problem. Thanks in advance.- Mark as New
FIXED THIS ISSUE --
Problem is a bug in the uClinux ftpd.c code. I found a blog from 2003 http://blog.gmane.org/gmane.linux.uclinux.devel/month=20061101/page=36 Code here just in case this link is flakey ************************** Subject: [BUG] ftpd Newsgroups: gmane.comp.gnu.inetutils.bugs Date: Fri, 29 Aug 2003 21:28:31 +0900 Hello I found a bug. if "nm ftpd | sort -n" show: 1001cba8 b bufs.135 1001ce78 b ctrl_addr 1001ce88 b data_source then ctrl_addr will be destroyed, and ftp client will get message like this: 425 Can't create data socket (56.0.0.135,0): Cannot assign requested address. diff -u ftpd.c_org ftpd.c --- ftpd.c_org Wed Jun 26 12:15:05 2002 +++ ftpd.c Fri Aug 29 21:15:41 2003 @@ -192,7 +192,7 @@ static char bufs[NUM_SIMUL_OFF_TO_STRS][80]; static char (*next_buf)[80] = bufs; - if (next_buf > (bufs+NUM_SIMUL_OFF_TO_STRS)) + if (next_buf >= (bufs+NUM_SIMUL_OFF_TO_STRS)) next_buf = bufs; if (sizeof (off) > sizeof (long)) ------------------------------------------------------------ When I introduced this change in my ftpc.c the problem is resolved. Anyone have any further comments on this and/or the above mentioned bug report? Thanks. /Martin ********************* Basically, a fix for this problem was submitted way back then and is not in the current "ftpd.c" file (in uClinux-dist/user/ftpd directory). I made the fix, tested it and it works great. I can now mget with no problems. Hope this helps someone else.
Topic Options
