Hi all,
I successfully compiled the 4.1 toolchain and also the most recent kernel from the git (2.6.35). Unfortunately they don't work together. I compiled a simple hello world and don't see any output. The executable is tagged to be for kernel 2.6.21. Does that mean it won't work with more recent kernels? If so, where do I get the kernel sources from? Thanks for any insights ... - JohannesLink Copied
Stupid me the kernel is included in the gcc-4.1 toolchain dir. Sorry for bothering you ...
- Johannes- Mark as New
You can get the linux sources from the git repository at sopc.et.ntust.edu.tw (as mentioned in the wiki).
OTOH it probably won't make a difference as the new system calles hooked up there won't be used in the glibc version used in the current toolchain.- Mark as New
Hi Johannes,
How did you succeed in rebuild the gcc 4.1 toolchain? Did you follow a wiki? Where did you find the sources? niosftp.com doesn't work anymore... Thanks in advance...
